[Qgis-user] QGIS 2.0.1 can't load most of the raster layer from my old project
William Kyngesburye
woklist at kyngchaos.com
Sun Sep 22 15:07:33 PDT 2013
Maybe a file limit? OSX has a 256 files open limit per process. I know with shapefiles that's at least 3 files per shapefile. But I don't remember raster files being left open. Maybe that's something new with QGIS 2, and why the project still works in 1.8.
You could also try checking the files outside of QGIS in a Terminal with gdalinfo (in the GDAL framework) to see if GDAL 1.10 is having trouble with any of the files.
On Sep 22, 2013, at 4:31 PM, Giacomo wrote:
> Apparently there are no differences between the files that are loading and that that are not. Most of them are .jpg files with relative aux.xml but I have GEOTIFF (and also Vector layers .shp )as well. All files are store inside different folder and sub folder but from the same folder some are loaded and some not.
> Thanks a lot for all!
> Best regards,
> Giacomo Marchioro
> Il giorno 22/set/2013, alle ore 23:01, William Kyngesburye <woklist at kyngchaos.com> ha scritto:
>> I don't see any packaging or build problems.
>> What kind of raster layers are not loading? What kind of raster layer are loading?
>> On Sep 22, 2013, at 4:30 AM, Giacomo Marchioro wrote:
>>> Thanks a lot! This is the log I attach you the project:
>>> Process: QGIS [347]
>>> Path: /Applications/QGIS.app/Contents/MacOS/QGIS
>>> Identifier: org.qgis.qgis2
>>> Version: 2.0.1 (2.0.1 [f738351])
>>> Code Type: X86-64 (Native)
>>> Parent Process: launchd [245]
>>> User ID: 504
>>> Date/Time: 2013-09-22 11:25:55.387 +0200
>>> OS Version: Mac OS X 10.8.4 (12E55)
>>> Report Version: 10
>>> Interval Since Last Report: 5882 sec
>>> Crashes Since Last Report: 5
>>> Per-App Interval Since Last Report: 3007 sec
>>> Per-App Crashes Since Last Report: 5
>>> Anonymous UUID: C5B70571-7F3E-433F-8875-521B435C3FB1
>>> Crashed Thread: 3
>>> Exception Type: EXC_CRASH (SIGABRT)
>>> Exception Codes: 0x0000000000000000, 0x0000000000000000
>>> Application Specific Information:
>>> abort() called
>>> Thread 3 Crashed:
>>> 0 libsystem_kernel.dylib 0x00007fff92c0e212 __pthread_kill + 10
>>> 1 libsystem_c.dylib 0x00007fff8ba6eb54 pthread_kill + 90
>>> 2 libsystem_c.dylib 0x00007fff8bab2dce abort + 143
>>> 3 org.qgis.qgis2 0x000000010402a46a myMessageOutput(QtMsgType, char const*) + 256
>>> 4 QtCore 0x0000000108b8d3e1 qt_message_output(QtMsgType, char const*) + 33
>>> 5 QtCore 0x0000000108b8d617 qt_message(QtMsgType, char const*, __va_list_tag*) + 183
>>> 6 QtCore 0x0000000108b8d7da qFatal(char const*, ...) + 170
>>> 7 QtCore 0x0000000108ce9016 QEventDispatcherUNIXPrivate::QEventDispatcherUNIXPrivate() + 438
>>> 8 QtCore 0x0000000108ce90af QEventDispatcherUNIX::QEventDispatcherUNIX(QObject*) + 47
>>> 9 QtCore 0x0000000108b97ffa QThreadPrivate::createEventDispatcher(QThreadData*) + 42
>>> 10 QtCore 0x0000000108b98678 QThreadPrivate::start(void*) + 264
>>> 11 libsystem_c.dylib 0x00007fff8ba6d7a2 _pthread_start + 327
>>> 12 libsystem_c.dylib 0x00007fff8ba5a1e1 thread_start + 13
>>> Thread 3 crashed with X86 Thread State (64-bit):
>>> rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x000000010c4d1c08 rdx: 0x0000000000000000
>>> rdi: 0x000000000000673f rsi: 0x0000000000000006 rbp: 0x000000010c4d1c30 rsp: 0x000000010c4d1c08
>>> r8: 0x00007fff77647278 r9: 0x000000010c4d15a0 r10: 0x0000000020000000 r11: 0x0000000000000206
>>> r12: 0x0000000000000003 r13: 0x000000010c4d1d40 r14: 0x000000010c4d2000 r15: 0x0000000108b98570
>>> rip: 0x00007fff92c0e212 rfl: 0x0000000000000206 cr2: 0x00007fff77640ff0
>>> Logical CPU: 0
>>> 2013/9/21 William Kyngesburye <woklist at kyngchaos.com>
>>> When an app crashes you should get a crash log. What's in it? (don't send to Apple)
>>> On Sep 21, 2013, at 11:18 AM, Giacomo wrote:
>>>> Hi all,
>>>> I've just installed QGIS 2.0.1 (Mac user) I'm trying to open my old project but QGIS 2.0 doesn't load most of the raster layers. "Handle bad layers" window appear but when a try to re-set the path QGIS crash. I've tried to open the same project with QGIS 2.8 and it works perfectly the window doesn't appear at all. Can anyone help me? Thanks a lot!
>>>> Best regards,
>>>> Giacomo Marchioro
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>>> http://www.kyngchaos.com/
>>> All generalizations are dangerous, even this one.
>>> <Parete EST.qgs>
>> "Mon Dieu! but they are all alike. Cheating, murdering, lying, fighting, and all for things that the beasts of the jungle would not deign to possess - money to purchase the effeminate pleasures of weaklings. And yet withal bound down by silly customs that make them slaves to their unhappy lot while firm in the belief that they be the lords of creation enjoying the only real pleasures of existence....
>> - the wisdom of Tarzan
"Those people who most want to rule people are, ipso-facto, those least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
