[Qgis-user] OpenLayers Plugin layers not saved in 64 bit versions	of Qgis 2.0.1
    David John Beaton Pearce
    david at sapura.com.my
    Sun Sep 22 19:59:27 PDT 2013
Resending this with more information after registering onto the Mailing List.
I see this on 2.0.1 64 bit Ubuntu and 64 bit Windows 7 with OpenLayers plugin 1.1.1
Install OpenLayers plugin
Create a vector layer to give a suitable lat/long based map region
Create a new OpenLayer layer, any will do.
Save As filename.qgs
Close Qgis
Reopen and open filename.qgs
Result OpenLayer layer is not listed or drawn, the first vector layer is drawn
I can see the missing layer listed in the .qgs xml
The same test on the Windows 32 bit version on XP works as expected. Reopening the .qgs project lists the layer and it is displayed
Regards
David
The contents of this e-mail are confidential and may be privileged. If you are not the intended recipient, please do not read, use, print, copy, forward or distribute the contents or disclose it to anyone. Instead, please inform us by return e-mail and delete it from your system immediately. Opinions, conclusions and other information in this message shall not be deemed or understood to be given nor endorsed by the Sapura Group, unless it is separately confirmed in writing by the relevant duly authorised personnel of the Sapura Group. All liability for computer viruses is excluded to the fullest extent permitted by law.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130923/bea1a3e3/attachment.html>
