[Qgis-user] Oracle - QGIS connection
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Sep 23 04:56:32 PDT 2013
Hi List,
This is happening in 2.0.1 too. As other things can connect to the database
from this machine I have to guess that it is a QGIS thing. I know it worked
previously but doesn't seem to any more.
Does it work for other folks? What are you entering into the parameters?
Thanks,
Jonathan
On 28 August 2013 14:33, Jonathan Moules <jonathanmoules at warwickshire.gov.uk
> wrote:
> Anyone?
> I'm using QGIS weekly build d61cb25 on windows 7.
> Thanks,
> Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130923/f9c9ca25/attachment.html>
