[Qgis-user] QGIS 2.0 - OSX - georeferencing plugin missing ?
Teodoro Laino teodoro.laino at gmail.com
Mon Sep 23 12:53:12 PDT 2013
Hi Larry,
thanks for your reply - I'm running OSX 10.8.4 (and installed Mt.Lion version)
I just followed your suggestions right now - I cleaned the /Application/QGIS folder (related to the night build) and installed a clean one from  kyngchaos.com.
From the same website I installed
GDAL Complete 1.10 framework package
and also the python modules. Python 2.7 is installed (together with other version that I use for other stuff).
After all that QGIS 2.0.1 is starting but Georeferencing is still not appearing (I have attached two snapshots, which I have sent you separately).
I also do not have any error message when opening QGIS - so I basically have no idea what else to try.
I would be glad to help to identify and reproduce the issue (at this stage we are at least in 2 to have this problem).
Best,
Teo
> On Sep 23, 2013, at 7:27 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Hello Teo,
>> On Mon, Sep 23, 2013 at 9:52 AM, Teodoro Laino <teodoro.laino at gmail.com> wrote:
>> well.. that's precisely my problem..
>> In the OSX build, in the Plugins -> manage and install plugins, there is no "Georeferences GDAL"
>> ---8<------snip----
>> That's the reason I'm thinking that something must be screwed up with the OSX build distribution. Or, again, something terribly obvious that I'm missing..
>> I just double-checked both 10.7-8 and 10.6 nightly builds and there are no issues with the 2.1 apps, with regards to the Georeferencer (that I can tell).
>> However, I did notice that there was still a 2.0.1 app in the 10.6 download archive folder (10.7-8 archive is fine). This happened during the switch from 1.9 to 2.0.1 to 2.1.0, and I forgot to prune it. If you have installed the 2.0.1 app, please remove it, as it is NOT a release distribution.
>> It is unclear what Mac OS X version you are using. If you are running 10.7-8, download the 2.0.1 release installer from kyngchaos.com. Then please make sure to remove ANY accidental 2.0.1 nightly installed, as the Kyngchaos.com installer will try to install into that application bundle instead of /Applications (this is also noted in the README).
>> If you are using Mac OS X 10.6, and are not needing to test the nightly builds, please wait until kyngchaos.com produces a 10.6 installer for the 2.0.1 branch. The nightlies are not 2.0.1 releases, but builds of the 2.1.0 master branch.
>> If the Georeferencer plugin still does not show up, then it is probably an issue with your supporting frameworks, which would need upgraded.
>> Please report on success or failure, either way. Thanks.
>> Regards,
>> Larry Shaffer
>> Dakota Cartography
>> Black Hills, South Dakota
>> Teo
>> On Sep 23, 2013, at 5:33 PM, skampus <stefano.campus at regione.piemonte.it> wrote:
>> > in Plugins-->manage and install plugins, check "Georeferencer GDAL"
>> > s.
>> > View this message in context: http://osgeo-org.1560.x6.nabble.com/QGIS-2-0-OSX-georeferencing-plugin-missing-tp5079279p5079298.html
>> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130923/2410411d/attachment.html>
