[Qgis-user] Python console doesnt open in Qgis 2.0
Oware Maungu oware at appliedgeo.org
Tue Sep 24 02:48:34 PDT 2013
That did it, the python console now opens.
Thanks alot.
On Tue, Sep 24, 2013 at 12:37 PM, Salvatore Larosa <lrssvtml at gmail.com>wrote:
> Hi,
> On Tue, Sep 24, 2013 at 11:27 AM, Oware Maungu <oware at appliedgeo.org>wrote:
>> Starting qgis from terminal shows the warning below:
>> Warning: loading of qt translation failed
>> [/usr/share/qt4/translations/qt_en_US]
>> The message below is also logged (Log Messages)
>> Couldn't load Python support library: Cannot load library
>> /usr/lib/qgispython: (/usr/lib/libqgispython.so: cannot open shared object
>> file: No such file or directory)
> that gives us any chance to solve the problem :-)
>> To upgrade qgis to the latest release i did # apt-get install qgis
> Can you try to run apt-get install --reinstall python-qgis
> python-qgis-common ?
>> About QGIS:
>> QGIS version 2.0.1-Dufour
>> Compiled against Qt4.8.1 Running against Qt4.8.1
>> Compiled against GDAL/OGR1.7.3 Running against GDAL/OGR1.7.3
>> Compiled against GEOS3.2.2-CAPI-1.6.2 Running against GEOS3.3.8-CAPI-1.7.8
>> PostgreSQL Client Version9.1.9 SpatiaLite Version3.1.0-RC2
>> QWT Version5.2.2 PROJ.4 Version470
>> QScintilla2 Version
>> Thanks
>> On Tue, Sep 24, 2013 at 12:11 PM, Salvatore Larosa <lrssvtml at gmail.com>wrote:
>>> Hi,
>>> On Tue, Sep 24, 2013 at 10:25 AM, Oware Maungu <oware at appliedgeo.org>wrote:
>>>> Hi all,
>>>> I've just upgraded to 2.0.1 from 1.8 through ubuntu sources.
>>>> However, the python console doesnt open when I click the
>>>> Plugins->Python Console menu item.
>>>> Has anyone encountered a similar issue ? Am running xubuntu 12.04, no
>>>> error is logged in the terminal.
>>> Please could you provide some more info ?
>>> Check log messages (at the bottom left) or whether you get some message
>>> by running qgis from shell.
>>> Best Regards,
>>> -SL
>>>> Thanks
>>>> Oware Maungu
>>>> Geospatial Developer | Applied Geomatics <http://appliedgeo.org>
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Salvatore Larosa
>>> linkedIn: http://linkedin.com/in/larosasalvatore
>>> twitter: @lrssvt
>>> skype: s.larosa
>>> IRC: lrssvt on freenode
>> Oware Maungu
> Salvatore Larosa
> twitter: @lrssvt
> skype: s.larosa
Oware Maungu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130924/9b34c2fe/attachment.html>
