[Qgis-user] Couldn't load plugin contour due an error when calling its classFactory() method
Chris Crook ccrook at linz.govt.nz
Tue Sep 24 11:11:30 PDT 2013
HI Paulo
I'm not familiar with the MacBook and configuring QGIS on it, but the problem is that the contour plugin uses a python module called matplotlib, and that in turn uses a python module called pyparsing.  The error message is saying that the pyparsing module is missing.
Unfortunately I cannot help further than that.  The pyparsing module is available at http://pyparsing.wikispaces.com/Download+and+Installation
but how you install it depends on how your python installation is set up.
When you have fixed this there may be another couple of python dependencies you may need to install, listed at
http://matplotlib.org/users/installing.html
Good luck
Chris
________________________________________
Sent: 25 September 2013 03:28
To: QGIS User
Subject: [Qgis-user] Couldn't load plugin contour due an error when calling     its classFactory() method
Hi Everybody,
I ' m a newcomer to QGIS and I'm finding so problems in running some of its plugins.
I have Qgis 1.8.0 - Lisboa, running on a MacBook Pro with OSX 10.6.8 (Snow Leopard).
On trying to load the "Contour" Plugin, I get the message below. Can anybody help me ?
On waiting for your answers, I thank you all in advance.
All the Best.
Paulo Gali
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 164, in startPlugin
    plugins[packageName] = package.classFactory(iface)
  File "/Users/pgmacedo/.qgis//python/plugins/contour/__init__.py", line 73, in classFactory
    from contour import Contour
  File "/Applications/QGIS.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 309, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "/Users/pgmacedo/.qgis//python/plugins/contour/contour.py", line 38, in
    import matplotlib as mpl
  File "/Library/Python/2.6/site-packages/matplotlib/__init__.py", line 115, in
    raise ImportError("matplotlib requires pyparsing")
ImportError: matplotlib requires pyparsing
Python version:
2.6.1 (r261:67515, Jun 24 2010, 21:47:49)
[GCC 4.2.1 (Apple Inc. build 5646)]
QGIS version:
1.8.0-Lisboa Lisboa,
Python path: ['/Applications/QGIS.app/Contents/MacOS/../Resources/python', '/Users/pgmacedo/.qgis//python', '/Users/pgmacedo/.qgis//python/plugins', '/Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins', '/Library/Frameworks/SQLite3.framework/Versions/3/Python/2.6', '/Library/Python/2.6/site-packages/numpy-override', '/Library/Frameworks/MapServer.framework/Versions/6.0/Python/2.6', '/Library/Frameworks/GDAL.framework/Versions/1.9/Python/2.6/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python/2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/Library/Python/2.6/site-packages/PIL', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode']
________________________________________________________________________
(Prof. Paulo Gali Macedo)
Departamento de FĂ­sica e Astronomia
Faculdade de Ciencias da Universidade do Porto
R. do Campo Alegre,  687
4169-007 Porto
        PORTUGAL
_________________
Tel . (+351)-220402854
HOME ADRESS:
 R. Hernani Torres, 39 - 7 Esq.
4200-320  Porto
        PORTUGAL
Home Tel .  (+351)-225021945
TM.        (+351)-965871512
e-mail:
pgmacedo at fc.up.pt<mailto:pgmacedo at fc.up.pt>
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
