[Qgis-user] Matplotlib not found with Qgis 2.0.1-1 OS X
William Kyngesburye
woklist at kyngchaos.com
Tue Sep 24 13:27:10 PDT 2013
Install my matplotlib package. When you do that, make sure to read the readme - I discovered the pyparsing requirement at the last minute of packaging, so you need to install it in the Terminal.
For the plugins, you may have leftovers from a previous 2.0 nightly dev build, the Mac installer sometimes doesn't remove old files. Try deleting QGIS from your Applications folder and reinstall.
On Sep 24, 2013, at 2:17 PM, Kurt Springs wrote:
> Hi,
> I recently upgraded Qgis to William Kyngeburye's 2.0.1-1. It is telling me "Could not find matplotlib module. Make sure matplotlib is installed." I get this message on both my MacPro running OS X Lion and my MacBook Pro running Mountain Lion. Is there a simple fix for this?
> Also, on my 13 inch MacBook Pro, It is telling me I have four invalid plugins: mapserver_export, osm, plugin_installer, and Processing. When I click on them, all of the three buttons (Upgrade all, Uninstall plugin, and Reinstall plugin) are greyed, so I can't just uninstall them. Is there anything I can, or should, do with them? It gives me a path through the QGIS.app package, but I don't want to delete something and have it crash the program.
> Thanks,
> Kurt
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
