[Qgis-user] Matplotlib not found with Qgis 2.0.1-1 OS X
Kurt Springs ferret_bard at mac.com
Tue Sep 24 14:54:18 PDT 2013
Okay, I'll just wait for the update.
Kurt
On Sep 24, 2013, at 5:50 PM, William Kyngesburye wrote:
> I have an update coming soon to fix some packaging problems, including bundling the required psycopg2.
> I don't know what the problem is with processing, it's a standard part of QGIS, can't be uninstalled, and can only be updated as a part of a QGIS installation.  Maybe it says it's invalid because of other packaging problems (try the update when it's ready).
> On Sep 24, 2013, at 4:33 PM, Kurt Springs wrote:
>> Thanks William,
>> For the most part your suggestions did it. The only problem still there is Processing. It claims to be installed at  /Applications/QGIS.app/Contents/MacOS/../Resources/python/plugins/processing). It is working fine on my Lion Machine. As before, I have no way to uninstall or reinstall it. It is telling me that pcopg2 is missing. I tried to use easy_install to install it but it said got the following error:
>> unable to execute clang: No such file or directory
>> error: Setup script exited with error: command 'clang' failed with exit status 1
>> Not sure what that meant.
>> Like I said, it's fine on my old MacPro with Lion.
>> Any ideas?
>> Kurt
>> On Sep 24, 2013, at 4:27 PM, William Kyngesburye wrote:
>>> Install my matplotlib package.  When you do that, make sure to read the readme - I discovered the pyparsing requirement at the last minute of packaging, so you need to install it in the Terminal.
>>> For the plugins, you may have leftovers from a previous 2.0 nightly dev build, the Mac installer sometimes doesn't remove old files.  Try deleting QGIS from your Applications folder and reinstall.
>>> On Sep 24, 2013, at 2:17 PM, Kurt Springs wrote:
>>>> Hi,
>>>> I recently upgraded Qgis to William Kyngeburye's 2.0.1-1. It is telling me "Could not find matplotlib module. Make sure matplotlib is installed." I get this message on both my MacPro running OS X Lion and my MacBook Pro running Mountain Lion. Is there a simple fix for this?
>>>> Also, on my 13 inch MacBook Pro, It is telling me I have four invalid plugins: mapserver_export, osm, plugin_installer, and Processing. When I click on them, all of the three buttons (Upgrade all, Uninstall plugin, and Reinstall plugin) are greyed, so I can't just uninstall them. Is there anything I can, or should, do with them? It gives me a path through the QGIS.app package, but I don't want to delete something and have it crash the program.
>>>> Thanks,
>>>> Kurt
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> The equator is so long, it could encircle the earth completely once.
