[Qgis-user] Can't use two base maps
Kevin Broderick ktb at kevinbroderick.com
Wed Sep 25 05:51:21 PDT 2013
I'm seeing the similar symptoms—"Could not draw Google Streets because:" or
"Could not draw OpenStreetMap because:" and no further information in the
dialog box. This seems to be happening to all except the last OpenLayer
layer added to the project—i.e. if I add a Google streets layer, it works.
I then add an OSM layer, and the Google Streets layer throws the above
error message, but the OSM layer works. If I then add a Bing layer, I get
the error if I try to have either the OSM or the Google layer rendered.
This is on Mac OS X.
On Wed, Sep 25, 2013 at 8:04 AM, KLGan <1klgan at gmail.com> wrote:
> Hi,
> Forgot to include computer specs, here...
> Ubuntu 13.04
> 2GB ram
> Intel T2080 @ 1.75GHz x 2
> OS type 32bit
> It is an old laptop, but still meet minimum requirement I guess.
> Thanks
> KLGan
>  On Sep 25, 2013 7:46 PM, "António M. Rodrigues" <amcrgrodrigues at gmail.com>
> wrote:
>> Hi,
>> It works fine with me (ubuntu 12.04, qgis2.01)
>> António
>> 2013/9/25 KLGan <1klgan at gmail.com>
>>> Hi,
>>> In QGIS 1.8, I'm able to have two base maps using the OpenLayer plugin.
>>> For example I could have the Google street map and the satellite map. And I
>>> can switch from one to the other by selecting and unselect the top most
>>> basemap in the layer panel.
>>> But I'm not able to do this anymore in 2.0, getting error like: QGIS can
>>> not draw "..........", giving no explanation.
>>> Is this capability removed in 2.0?
>>> Thanks  :-)
>>> KLGan
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130925/1bd53161/attachment.html>
