[Qgis-user] UI - Double clicking a layer to add it
Andreas Neumann
a.neumann at carto.net
Thu Sep 26 11:45:36 PDT 2013
For Postgis and Oracle there are options in the "Settings" --> "Options"
--> "Datasources".
There you can define what double click on a table means.
But yes, it is a bit inconsistent.
I think I got used to it. No major trouble, but would be nice if
behaviour could be unified.
Andreas
Am 26.09.2013 19:15, schrieb Jonathan Moules:
> Hi Larry,
> No problem. I just figured I should ask first as there may have been a
> reason for it.
> Don't worry, I know where the tracker is, this is report number 9 for
> today. ;-)r
> Reported as http://hub.qgis.org/issues/8700
> Regards,
> Jonathan
> On 26 September 2013 18:10, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> Hi Jonathan,
>> On Thu, Sep 26, 2013 at 10:19 AM, Jonathan Moules <
>> jonathanmoules at warwickshire.gov.uk> wrote:
>>> Hi List,
>>> I've noted some inconsistency in what happens when you double click a
>>> layer in an effort to add it to QGIS.
>>> One of several possible things happens:
>>> Add Vector Layer:
>>> - Double clicking a file closes the "Open an OGR supported Vector Layer"
>>> dialog but keeps open the "Add vector layer" dialog.
>>> Add Raster Layer:
>>> - Double clicking a raster closes the dialog and adds the file
>>> immediately to QGIS.
>>> Add Oracle / SpatiaLite tables (maybe the other databases too?)
>>> - Double clicking a table brings up a "Query Builder" for that table.
>>> Add WMS and Add WCS
>>> - Double clicking does nothing.
>>> Add WFS
>>> - Opens up "Expression string builder" dialog
>>> To me at least this is very wrong. They should all behave in the exact
>>> same way when I double click something. Personally I'd say the raster way
>>> is the correct one - that's how all other applications work when I double
>>> click something to add, be it a GIS or a text editor or anything.
>>> I appreciate why opening query/expression builders may be useful, but I
>>> don't think it should be the default action on double-clicking.
>>> Does anyone else have an opinion on this?
>> Yes, this is inconsistent and needs addressed. Please create a new bug
>> issue ticket [0], if one does not already exist.
>> Thank you for reporting on this.
>> [0] http://hub.qgis.org/wiki/quantum-gis/Bugreports
>> Regards,
>> Larry
>>> Cheers,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
