[Qgis-user] ordering an attribute table
Michael Spencer
spencer.mike.r at gmail.com
Fri Sep 27 08:14:21 PDT 2013
Senile moment... this is the correct file!
http://ubuntuone.com/3Y9YM5RaMPaklMI25nrtMY
Column is SLsum or SLmean (should both be the same from one raster), or
SL2sum/mean. First set have nan values and second have -999 values, I
removed the null using "column" is null.
On 27 September 2013 16:04, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> I don't see any null or no numbers in that column. The field is a integer
> type which can't have NULL or non numbers in it to start with.
> - Nathan
> On Sat, Sep 28, 2013 at 12:56 AM, Michael Spencer <
> spencer.mike.r at gmail.com> wrote:
>> It's a 5km grid of Scotland. I've stuck it on Ubuntu One. Zip file is
>> 54.2 kB, located here: http://ubuntuone.com/5xQiQg5d2Gel1FYYhZDwee
>> There's no super rush, it's for a blog how to for displaying two raster
>> values at the same time.
>> Thanks in advance,
>> Michael
>> On 27 September 2013 15:44, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>> How big is your layer and could you upload it to somewhere for me, and
>>> others, to test (note that I'm going to bed now so may not answer until
>>> tomorrow)
>>> - Nathan
>>> On Sat, Sep 28, 2013 at 12:38 AM, Michael Spencer <
>>>> Thanks Nathan,
>>>> I see where you're coming from, but it's not working. The regex selects
>>>> all values. I wonder if the problem lies in the data table? The column
>>>> format is 'real' and I generated the column using the zonal statistics
>>>> plugin from an underlying raster overlain with a regular grid. Null values
>>>> seem to have been produced for cells outside the raster, with nan produced
>>>> where the raster has no data.
>>>> I recoded the raster output from grass to classify the no data values
>>>> as -999. How do I go about selecting these? I thought "column" < 0 would
>>>> work, but this doesn't select anything.
>>>> Another option could be to use the raster tool and vectorise it,
>>>> unfortunately this doesn't produce a whole grid as it only outputs integer
>>>> values and joins some cells together.
>>>> On 27 September 2013 13:44, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>>>> Hey Michael,
>>>>> Try this expression using the advanced selection feature:
>>>>> regexp_match('column', '\\d*') = 1
>>>>> This is using a regex to match column as any number of digits (\\d*).
>>>>> If it's not a digit it will return 0 so you want to only select the ones
>>>>> that = 1.
>>>>> - Nathan
>>>>> On Fri, Sep 27, 2013 at 10:16 PM, Michael Spencer <
>>>>>> Date: Thu, 26 Sep 2013 18:18:10 +0200
>>>>>> From: Bernhard Str?bl <bernhard.stroebl at jena.de>
>>>>>> Hi,
>>>>>> Am 26.09.2013 18:07, schrieb Michael Spencer:
>>>>>> > Having a strange problem at the moment.
>>>>>> > If I open a vector attribute table and click on a column heading to
>>>>>> sort
>>>>>> > the column then this doesn't seem to work. The column contains
>>>>>> mainly
>>>>>> > numbers with some NA and some NULL strings.
>>>>>> > The sort action groups most together most NA and NULL, and orders
>>>>>> the
>>>>>> > numbers, but some strings slip through the gaps and appear where
>>>>>> they
>>>>>> > aren't wanted in the number sequence!
>>>>>> > I'm working in QGIS 2.0.1 on Ubuntu 12.04.
>>>>>> > The reason I want to do this is to delete all records that aren't
>>>>>> > numeric, so if there's a neater way to accomplish this that would
>>>>>> be great!
>>>>>> A neater way would be to select the records in question and then
>>>>>> simply
>>>>>> delete the selected. Hint select for nulls with
>>>>>> <code>"my_field" is null</code>
>>>>>> Thanks Bernhard, this was my original choice. Unfortunately I find
>>>>>> the select tool a total black box and can't get my head around it. Your
>>>>>> suggestion works for entries with 'null' in, but I can't get a response
>>>>>> when I want to select 'nan' values. I've tried as:
>>>>>> <"field" is nan>
>>>>>> <"field" is 'nan'>
>>>>>> <"field" = 'nan'>
>>>>>> Both with no joy. Is there a crib sheet somewhere with basic options
>>>>>> on?
>>>>>> Ta,
>>>>>> Michael
>>>>>> Bernhard
>>>>>> > Ta,
>>>>>> > Michael
>>>>>> _______________________________________________
>>>>>> Qgis-user mailing list
>>>>>> Qgis-user at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130927/010df718/attachment.html>
