[Qgis-user] Authentication in QGIS Server (WFS Service)
Antonio Vico avicomartin at gmail.com
Sun Sep 29 09:34:54 PDT 2013
I tested basic protection whit .htaccess file in the directory. This
require user/password for access with a browser but defining a wfs server
like http://my_host/cgi-bin/qgis_mapserv.fcgi?map=/var/www/Test01/mymap.qgsin
qgis desktop can acces without restrictions to the map file.
Here my http configuration:
file .htaccess in directory /var/www/Test01 (to protect)
AuthType BasicAuthName "Authentication Required"AuthUserFile
"/etc/apache2/htpasswd"Require valid-user
modification in apache config file
<Directory "/var/www/Test01">  AllowOverride AuthConfig  # The Options
below is an example. Use what you deem is necessary.  Options
MultiViews Indexes SymLinksIfOwnerMatch IncludesNoExec  Order
allow,deny  Allow from all</Directory>
2013/9/29 aperi2007 <aperi2007 at gmail.com>
> the authentication usually in the wfs/wms systems is in the web server
> front-end.
> On 29/09/2013 00:00, Antonio Vico wrote:
>> Hi all,
>> I am testing a "Qgis stack" for a project. I want use Qgis server for WMS
>> and WFS services, Qgis desktop for digitalize data and Qgis web client for
>> share.
>> To do this I use a postgresql/postgis backend and this is my architecture:
>> I store data in a postgresql/postgis database in a remote server with
>> different users (and different privileges) that contains qgis server too.
>> For share information I create a qgis project (mymap.qgs for example)
>> that add several layers connecting directly to the database sharing fields
>> that I want (with user and password according to the database) and put this
>> qgis project to share in qgis server in a WFS service. (Direct connexion to
>> the database in remote clients is not possible due the internet connexion
>> speed and the amount of data).
>> Open remotely this wfs service from qgis desktop work fine: qgis desktop
>>  can connect remotely to the wfs service ( http:/myserver/cgi-bin/qgis_**
>> mapserv.cgi?map=/paht/to/**mymap.qgs ) without problems and I can
>> add/modify data in database, but there is my problem: Someone can connect
>> to the wfs service (http:/myserver/cgi-bin/qgis_**
>> mapserv.cgi?map=/paht/to/**mymap.qgs has not restriction) and acces to
>> the data without any identification.
>> In qgis projects properties i can't find authentication propierties for
>> WMS/WFS services and the question is
>> Can I put some authentication system in qgis server for wfs service?
>> If yes, how to?
>> ______________________________**_________________
>> Qgis-user mailing list
>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130929/4756c4bb/attachment.html>
