[Qgis-user] qtiles plugin
daniel
idnael at gmail.com
Mon Sep 30 13:54:39 PDT 2013
2013/9/30 Alexander Bruy <alexander.bruy at gmail.com>:
> Hi,
> yes QTiles plugin works fine here with both QGIS 2.1
> and QGIS 2.0.1.
> If you download sources from GitHub, you should remenber
> that this is sources, not ready-to-use plugin and you should
> perform all necessary operations (compiling resources,
> building translations and ui) by yourself. Casual users should
> install plugin from repository.
Did you installed that plugin from the repository? I can't find it
there! And I'm still struggling with compilation errors.
Can (someone!) please send me a pre-compiled version for Linux (or
windows)? maybe it will work!
