[Qgis-user] OpenStreetMap in QGIS
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Wed Apr 2 04:34:49 PDT 2014
Hi Jonathan,
See the following tickets for problem with the OpenLayers plugin and QGIS
Master:
http://hub.qgis.org/issues/9626
 http://hub.qgis.org/issues/9649
Meanwhile, you probably  can download the relevant tiles and style them,
which is not very convenient!
Cheers,
Saber
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 02 April 2014 12:27
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] OpenStreetMap in QGIS
Hi List,
So, I know that QGIS is supposed to integrate nicely with OSM, however I'm
trying to use the "OpenLayers Plugin" 1.1.2 but it seems prone to crashing
QGIS (2.3 - nightly snapshot) and never actually loads any of the mapping.
So how do I get OSM as a baselayer in QGIS? Or is this the proper way but
I'm just unlucky?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell products, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140402/a1c1a9b9/attachment.html>
