[Qgis-user] How can I assign an attribute to a layer -auto fill if it contains in another layer
Saber Razmjooei
saber.razmjooei at lutraconsulting.co.uk
Thu Apr 3 05:52:20 PDT 2014
You can use Point Sampling plugin.
Cheers,
Saber
PS: for these type of questions, you can use QGIS user mailing list. Each mailing list serves a different purpose and your email will be likely to be ignored.
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of AJAY KUMAR MULAKALA
Sent: 03 April 2014 13:43
To: qgis-user at lists.osgeo.org; qgis-tr-request at lists.osgeo.org; qgis-community-team at lists.osgeo.org; qgis-developer at lists.osgeo.org; qgis-tr at lists.osgeo.org
Subject: [Qgis-user] How can I assign an attribute to a layer -auto fill if it contains in another layer
Dear all
I have a Point layer (fire stations) and Polygon (Localities/Cities)
I would now like to assign polygon attribute (city name) to point attribute (locality- an existing empty column (or) a new column) is the point is containing in the polygon.
if city consist with a fire station, then that city name is to add/assign to fire station in a new/existing column...?
Regards
AJAY
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140403/309833ac/attachment.html>
