[Qgis-user] query
Anita Graser
anitagraser at gmx.at
Sat Apr 5 05:00:40 PDT 2014
Hi Nishant,
Am 05.04.2014, 10:20 Uhr, schrieb Nishant Alag <alagnishant at gmail.com>:
> i used srtm_52_06 to obtain aspect and slope. Aspect in one sense seems
> fine but slope is not undestandable in terms of figures, i chose slope in
> percent but it gives me figures ranging from 0 to 1.15778e+07. How to
> convert it into percentage or what would be the stepwise process i.e.
> using srtm as a input file.
The SRTM data is in WGS84 EPSG:4326, right? That means that x,y are in
degrees and z is in meters. Calculating slope will give strange results if
you don't use the correct z factor settings:
If everything is in meters, use z factor 1.0 (default).
If x/y is in degree and z in meters, use z factor 111120.
If x/y degree and z is feet, use z factor 370400.
Best wishes,
Anita
anitagraser.com
