[Qgis-user] misaligned openlayer corrects itself when panned
Carlos Cerdán sig.upagu at gmail.com
Tue Apr 8 06:28:47 PDT 2014
Same behavior with my QGIS 2.2 - Ubuntu. I took it as normal because of the
automatic change of Google SRC. Is it?
Carlos
2014-04-06 8:06 GMT-05:00 Jake Maier <j.m at jmforestry.com>:
> Hi,
> I have an issue with openlayer for quite some time meaning  it was already
> in previous versions. I use now 2.2 master.
> When I open a Google image the first time, I see my layers correctly, but
> underneath are 6 or so maps of the total earth in a row
> I only need to pan a tiny bit and it will start correcting itself.
> Sometime it will be ok with the first pan (or zoom) and sometimes it will
> be off maybe 100 meters of so.
> A second pan will straighten everything out. I googled the problem and
> found one related but still different problem with Openlayers.
> Any ideas what's wrong, and what I should do? (Ticket?)
> Jake
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140408/e990a305/attachment.html>
