[Qgis-user] 300 plugins
Stott, James fmrojst at fylkesmannen.no
Wed Apr 9 23:04:23 PDT 2014
I think a page on preferred policy (or an update to the existing pages on the website) regarding plugins would be good. Things have changed a little bit regarding plugins over the last couple of years.
Something I would like to see included is that menu items are added in the code using QCoreApplication.translate, so it is then easier to translate the GUI items from someone else's plugins for your users if you need to.
James
-----Opprinnelig melding-----
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne av Blumentrath, Stefan
Sendt: 9. april 2014 22:34
Til: cavallini at faunalia.it; Lene Fischer; qgis-user; GFOSS.it
Emne: Re: [Qgis-user] 300 plugins
Several plugins already come with a more comprehensive description (in the plugin manager) of what the plugin does (e.g. Data Driven Input Mask plugin). For me personally, that would be enough information to start with (for details, trying the plugin is nevertheless almost inevitable in most cases).
I guess most of the plugins documented that way are "newer" ones (or at least with newer versions) which make use of the excellent, relatively new plugin manager interface and the corresponding options in metadata.txt.
Yet, there seem to be different ways to get that information into the plugin manager: the "about" section in metadata.txt which e.g EasyCustomLabeling plugin uses, but there must be also another way as the Data Driven Input Mask plugin does not have such an about section in the metadata.txt (but it has a description in the plugin manager).
As for the older "description" section in metadata.txt (which is printed in bold letters in the plugin manager) I noticed quite different usage among plugin-devs. Compare for example, "MultiEdit" and "New Memory Layer".
The best way to improve the situation might be to simply write an email to all plugin devs, inform them about the preferred policy regarding documentation and encourage them to update their plugins.
Just an idea...
Cheers
Stefan
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Paolo Cavallini
Sent: 9. april 2014 18:06
To: Lene Fischer; qgis-user; GFOSS.it
Subject: Re: [Qgis-user] 300 plugins
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Il 09/04/2014 09:32, Lene Fischer ha scritto:
> Hi Paolo,
> Yes it is a mailestone - All these plugins - Wonderful tools for free use!!! Thansk to all developers.
> I would only wish they were better descriped.
> Yesterday I took some time to read  the list, but most of the plugins are difficult to know how they work.
> I have to install - try- and uninstall.
> A few plugins has examples and video - brilliant!!
> Hope others developers will follow this trend.
Agreed - I think many users could contribute a description, it will be easy to add it afterwards.
All the best.
Paolo Cavallini - www.faunalia.eu
Corsi QGIS e PostGIS: http://www.faunalia.eu/training.html
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
Comment: Using GnuPG with Icedove - http://www.enigmail.net/
iEYEARECAAYFAlNFb9kACgkQ/NedwLUzIr4z2wCfciRmSEGFyatpkYh8FiP7pvfF
jMoAn1m5Pcvu/uR+JCtcdt+kRVZrgbk4
=g9So
-----END PGP SIGNATURE-----
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
