[Qgis-user] Problem with Rasterize (Vector to raster) tool
Saber Razmjooei saber.razmjooei at lutraconsulting.co.uk
Thu Apr 10 07:16:18 PDT 2014
In QGIS, ensure Processing plugin is enabled.
>From Processing interface, change the interface to Advanced (bottom of the toolbar)
Within the module search, type v.to.rast
>From the module list, select v.to.rast.attribute
Fill in appropriate boxes and hit Run.
Cheers,
Saber
Saber Razmjooei
Lutra Consulting
 <http://www.lutraconsulting.co.uk/> www.lutraconsulting.co.uk
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Colin D. MacLeod
Sent: 10 April 2014 14:20
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Problem with Rasterize (Vector to raster) tool
Hi All,
I’m a fairly experienced GIS user, but I’m new to QGIS. I’m using version 2.2, and I’m trying to convert a point data layer into a raster data layer using the Rasterize tool. The point data layer has an integer field with a value of 1 for all records, and I want to make a raster data layer which has a value of one for each cell which has at least one point in it (some cells have more than one point in them). When I use the Rasterize tool, it creates the raster data layer fine, but all cells with have points in them appear to have a value of 0.995968. I’ve tried editing the gdal code (even making the resulting raster data layer an integer layer), but I still cannot get it to produce a raster with a value of 1 rather than just a number very close to one.
Does anyone have any suggestions of where I might be going wrong and/or how to solve this issue?
On a related note, is it possible to use the Rasterize tool to work out the average or total values for all the points which fall in each grid cell? If so, how (I can’t find anything in the gdal instructions themselves which would suggest this is possible, but I might be missing something). If this isn’t possible to do with the Rasterize tool, are there other tools in QGIS which can do this?
Thanks for any help anyone can give on this.
All the best,
Colin
GIS IN ECOLOGY - Providing Training, Advice And Consultancy On The Use Of GIS In Ecology
Web: www.GISinEcology.com Email: info at GISinEcology.com
Need to ask a question about using GIS? Try the GIS In Ecology Forum: www.GISinEcology.com/GIS_in_Ecology_forum.htm
Books From GIS In Ecology Staff:
An Introduction To Using GIS In Marine Biology; RRP: £44.99
An Introduction To Using GIS In Marine Biology: Supplementary Workbook One - Creating Maps Of Species Distribution; RRP: £19:99
An Introduction To Using GIS In Marine Biology: Supplementary Workbook Two - Working With Raster Data Layers; RRP: £19.99
If you wish to purchase these books, visit: http://www.gisinecology.com/Book_Shop.htm
To help the environment, please do not print out this email unless it is unavoidable.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
If this email contains a quote or offer to sell pro
 ducts, carry out work or perform services then our standard terms and conditions (which can be found at http://www.lutraconsulting.co.uk/downloads/Lutra%20Consulting%20Standard%20Terms%20and%20Conditions.pdf shall apply unless explicitly stated otherwise.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140410/2d0ad302/attachment.html>
