[Qgis-user] Tools of Grass and SAGA do not work
Andrés Ocaña Carretón andresocaac at yahoo.es
Thu Apr 10 14:31:40 PDT 2014
Hi!
Thanks all for your support.
Both GRASS and SAGA are provided by the standalone version of QGIS 2.2.
As if that were a problem in my computer, I installed the program on two computers, one with XP and one with Vista. With XP works perfectly. In Vista, I getthe same errors. So I guess the problem must be in the OS.
The Python console also gives errors when run. Can it be related?
"No se pudo abrir la consola de Python:
  File "", line 2, in
  File "C:/PROGRA~1/QGISVA~1/apps/qgis/./python\console\console.py", line 43, in show_console
    _console = PythonConsole( parent )
  File "C:/PROGRA~1/QGISVA~1/apps/qgis/./python\console\console.py", line 75, in __init__
    self.console = PythonConsoleWidget(self)
  File "C:/PROGRA~1/QGISVA~1/apps/qgis/./python\console\console.py", line 103, in __init__
    self.shellOut = ShellOutputScintilla(self)
  File "C:/PROGRA~1/QGISVA~1/apps/qgis/./python\console\console_output.py", line 103, in __init__
    self.insertInitText()
  File "C:/PROGRA~1/QGISVA~1/apps/qgis/./python\console\console_output.py", line 145, in insertInitText
    socket.gethostname())
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe9 in position 4: ordinal not in range(128)
Versión de Python:
2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
Versión de QGIS:
2.2.0-Valmiera 'Valmiera', c3a2817
Ruta de Python:
['C:/PROGRA~1/QGISVA~1/apps/qgis/./python/plugins\\processing', 'C:/PROGRA~1/QGISVA~1/apps/qgis/./python', u'C:/Users/Andr\xe9s/.qgis2/python', u'C:/Users/Andr\xe9s/.qgis2/python/plugins', 'C:/PROGRA~1/QGISVA~1/apps/qgis/./python/plugins', 'C:\\PROGRA~1\\QGISVA~1\\bin\\python27.zip', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\DLLs', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\plat-win', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\lib-tk', 'C:\\PROGRA~1\\QGISVA~1\\bin', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\PIL', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\win32', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\win32\\lib', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\Pythonwin',
 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win32.egg', 'C:\\PROGRA~1\\QGISVA~1\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode', 'C:\\PROGRA~1\\QGISVA~1\\apps\\qgis\\python\\plugins\\fTools\\tools']"
Can it be related?
GRAAS and SAGA are disabled in the configuration of the processing tab.
Are there any known problems with this version of QGIS and Vista? Is installing another version could solve?
Thanks
El Jueves 10 de abril de 2014 22:59, Andrés Ocaña Carretón <andresocaac at yahoo.es> escribió:
Hi!
Both GRASS
As if that were a problem in my computer, I installed the program on two computers, one with XP and one with Vista. With XP works perfectly. In Vista, I get the same errors. So I guess the problem must be in the OS.
The Python console also gives errors when run (file attached). Can it be related?
thanks
El Jueves 10 de abril de 2014 9:42, Jean-Roc Morreale <jr.morreale at enoreth.net> escribió:
Donovan > Both GRASS and SAGA are provided by the standalone version of
QGIS 2.2
Le 2014-04-10 02:51, Saulteau Don a écrit :
> Hi Andres,
> You probably just have to install GRASS [1] and SAGA [2] because those
> aren't included with QGIS. They are entirely separate software
> packages =)
> Then you will probably have to configure the processing toolbox [3] so
> that the GRASS and SAGA tools can be used. Those can be found in the
> "providers" portion.
> Another option is OSGeo4W [4] which provides an installer that will
> get all or any of the above for you (qgis, saga, grass, etc...).
> Donovan
> [1] http://grass.osgeo.org/download/software/ms-windows/[3]
> [2] http://sourceforge.net/projects/saga-gis/[4]
> [3] https://www.qgis.org/en/docs/user_manual/processing/3rdParty.html
> [5]
> [4] https://trac.osgeo.org/osgeo4w/[6]
> On Wed, Apr 9, 2014 at 3:00 PM, Andrés Ocaña Carretón
> <andresocaac at yahoo.es> wrote:
>> Hi!
>> I has started to use QGis 2.2 Valmiera. The O.S. of my computer is
>> Windows Vista Home Premium 32 bits. I has downloaded QGis of
>> official website www.qgis.org [1]. I has used the QGis Standalone
>> Installer version 2.2 (32 bit).
>> When I run the tools GRASS and SAGA the following error message is
>> displayed:
>> "This algorithm requires GRASS (or SAGA) to be run. Unfortunately,
>> it seems that GRASS (or SAGA) is not installed in your system, or it
>> is not correctly configured to be used from QGIS"
>> How I can fix the problem?
>> Tanks
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140410/bd402474/attachment.html>
