[Qgis-user] QGIS Processing broken in Master
Werner Macho
werner.macho at gmail.com
Sun Apr 20 02:06:08 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
confirmed..
trying to compile master the first error I get is:
- -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
CMake Error at python/plugins/processing/CMakeLists.txt:3
(ADD_SUBDIRECTORY):
add_subdirectory given source "admintools" which is not an existing
directory.
followed by a lot of messages in this style .. basically all external
tools like gdal, grass, grass7, taudem, saga, otb, r, lidar
- -- Ctest Binary Directory set to:
/home/macho/dev/cpp/QGIS/build/output/bin
- -- Configuring incomplete, errors occurred!
CMakeList missconfiguration?
regards
Werner
On 04/20/2014 10:32 AM, Filipe Dias wrote:
> Hi
> I just did a clean installation of QGIS Master on Ubuntu 12.04
> (also deleted ./qgis2) and Processing is broken. In the plugin
> manager this message shows up:
> *This plugin is broken* Missing metadata file
> Installed version: ? (in
> /usr/share/qgis/python/plugins/processing) Available version:
> 2.2.0-1 (in QGIS Official Plugin Repository)
> However, in /usr/share/qgis/python/plugins/processing there's an
> apparently normal metadata.txt file:
> [general] name=Processing description=Spatial data processing
> framework for QGIS category=Analysis version=2.0
> qgisMinimumVersion=2.0
> author=Victor Olaya email=volayaf at gmail.com website=www.qgis.org
> icon=images/alg.png
> class_name=ProcessingPlugin
> Does anyone else have problems with Processing?
> Cheers F.
> _______________________________________________ Qgis-user mailing
> list Qgis-user at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iEYEARECAAYFAlNTjfAACgkQDAH1YiCxBgmLAgCfb9xmT2biZPNxGWmvUo1ZoSqm
QXQAnA85hOKBTrkmtrtYZHu+oIzPz5cG
=JxWh
-----END PGP SIGNATURE-----
