[Qgis-user] Add a wms layer from startu macro
Andrea Peri
aperi2007 at gmail.com
Thu Apr 24 05:04:29 PDT 2014
THX Giovanni forma tour precious help.
I cannot use a file in .qgis2 folder. Because this mean to have a setup
phase before to open the project. But i hope to apply the code directly
inside the qgis project. Your code is really interesting.
Many thx,
Andrea
Il 24/apr/2014 13:55 "G. Allegri" <giohappy at gmail.com> ha scritto:
> You can write a startup.py file and put it into the <user>/.qgis2/python
> folder.
> It will be loaded and executed, so you could check for internet
> availability with something as simple as:
> import urllib2
> url = <your_wms_server_getcapabilities_service>
> try:
> urllib2.urlopen(url)
> except urllib2.URLError, e:
> print "Could not connect"
> Last time I needed it I used the following (with various adaptations):
> import sys
> import socket
> import time
> host = <my_url>
> port = <my_port_number>
> # type => ["tcp" or "udp"]
> type = sys.argv[3]
> test = ""
> if len(sys.argv) > 4 :
> test = sys.argv[4]
> while 1 :
> if type == "udp":
> s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
> else:
> s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
> s.settimeout(5)
> try:
> if type == "udp":
> s.sendto("--TEST LINE--", (host, port))
> recv, svr = s.recvfrom(255)
> s.shutdown(2)
> print "Success connecting to " + host + " on UDP port: " + str(port)
> else:
> s.connect((host, port))
> s.shutdown(2)
> print "Success connecting to " + host + " on TCP port: " + str(port)
> except Exception, e:
> try:
> errno, errtxt = e
> except ValueError:
> print "Cannot connect to " + host + " on port: " + str(port)
> else:
> if errno == 107:
> str(port)
> else:
> print e
> if test != "C" :
> sys.exit(0)
> s.close
> time.sleep(1)
> Giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140424/f025ec3c/attachment.html>
