[Qgis-user] Raster calculator question
Nathan Woodrow
madmanwoo at gmail.com
Fri Apr 25 02:08:16 PDT 2014
This would require QgsExpression to be extended to support rasters.
Not sure how much work that would be.
On 25/04/2014 7:02 pm, "kimaidou" <kimaidou at gmail.com> wrote:
> Hi Andreas,
> I totally agree with the benefit of using SQL-like syntax as in
> expressions to calculate rasters.
> I would prefer something like
> CASE
> WHEN raster1 at 1 > raster2 at 1 THEN raster1 at 1
> ELSE raster2 at 1
> END
> Having to multiply the result of a condition (0 or 1) by the band value to
> actually get the band values seems cumbersome for some users.
> Thanks for raising this issue.
> Michael
> 2014-04-24 15:25 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi Carlos,
>> Thanks a lot. This works fine.
>> Seems I first have to get used to the raster calculator syntax. Would be
>> great if it would use the expression editor as is used almost everywhere
>> else.
>> Andreas
>> Am 24.04.2014 12:57, schrieb Carlos Cerdán:
>> > Hi Andreas:
>> > Yes, it always evaluates to true because of "OR" condition , so try:
>> > (lake_mask > 0) * lake_mask + (lake_mask<=0)*dtm
>> > Good luck
>> > Carlos
>> > 2014-04-24 1:53 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>> >> Hi,
>> >> I have a hard time understanding the raster calculator syntax.
>> >> I would like to merge two rasters: DTM and lake mask. Let's call the
>> one
>> >> dtm and the other lake_mask.
>> >> When the lake_mask has a value > 0 then I would like to take the value
>> >> of the lake_mask, otherwise the value of the dtm.
>> >> What would an appropriate syntax look like?
>> >> I tried something along
>> >> ((lake_mask > 0) * lake_mask) OR dtm
>> >> But all I get in the resulting grid are values of 1. I guess it is
>> >> because it always evaluates to true?
>> >> Thanks for your help.
>> >> Andreas
>> >> _______________________________________________
>> >> Qgis-user mailing list
>> >> Qgis-user at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140425/89ce0557/attachment.html>
