[Qgis-user] The project file copy is dismissed ?
Jürgen E. Fischer jef at norbit.de
Fri Apr 25 14:51:16 PDT 2014
Hi Andrea,
On Fri, 25. Apr 2014 at 20:33:08 +0200, aperi2007 wrote:
> We notice that in the qgis 2.2 version .
> When open a project file "test2.qgs"
> QGIS will create a new file named "test2.qgs~"
> Instead in the dev version this file is no more create.
> Is this a valuated change or a unwanted bug ?
> We like the remove of the copy file because it will cause the lost of
> the original project file when it was read-only.
There was a change.  If the original project file is not writable, it won't be
renamed and in turn not overwritten.
See http://hub.qgis.org/issues/9617
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
QGIS PSC member (RM)      Germany                      IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
