[Qgis-user] Raster calculator question
Alex Mandel
tech_dev at wildintellect.com
Mon Apr 28 20:41:46 PDT 2014
GDALInfo "Band NODATA value. " if known. In the case where it's not set
in the header of the file then you have visually inspect the raster
using the info tool to figure out what nodata is in use. Generally all
rasters in the same set from a given source use the same nodata (for
batching purposes).
Then you can use GDAL_Translate to assign -a_nodata value:
Thanks,
Alex
On 04/28/2014 10:27 AM, kimaidou wrote:
> Hi Andreas
> About no data, I tried many things with no luck : NULL, none, 0, etc. If
> someone knows, please help (and update documentation if possible).
> I would like to change the nodata value, but could not find any way. It
> seems Grass can do it via the r.null alg, but it is not yet in Processing.
> Some tools in QGIS, related to GDAL, seem to be able to replace a know
> nodata value into another one. But it is often a chicken and egg problem,
> since we do not always know the nodata value (or I am missing some other
> tools like command line gdal to get it ?)
> Cheers
> Michael
> 2014-04-28 16:26 GMT+02:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> Again on the raster calculator: I noticed that nodata raster cells
>> cannot be detected. They seem to be ignored. Is there any trick to query
>> nodata cells? They are explicitly set to nodata, not to 0.
>> Andreas
>> Am 24.04.2014 12:57, schrieb Carlos Cerdán:
>>> Hi Andreas:
>>> Yes, it always evaluates to true because of "OR" condition , so try:
>>> (lake_mask > 0) * lake_mask + (lake_mask<=0)*dtm
>>> Good luck
>>> Carlos
>>> 2014-04-24 1:53 GMT-05:00 Andreas Neumann <a.neumann at carto.net>:
>>>> Hi,
>>>> I have a hard time understanding the raster calculator syntax.
>>>> I would like to merge two rasters: DTM and lake mask. Let's call the one
>>>> dtm and the other lake_mask.
>>>> When the lake_mask has a value > 0 then I would like to take the value
>>>> of the lake_mask, otherwise the value of the dtm.
>>>> What would an appropriate syntax look like?
>>>> I tried something along
>>>> ((lake_mask > 0) * lake_mask) OR dtm
>>>> But all I get in the resulting grid are values of 1. I guess it is
>>>> because it always evaluates to true?
>>>> Thanks for your help.
>>>> Andreas
