[Qgis-user] Am I out of luck?
Thomas Colley t.colley at neath-porttalbot.gov.uk
Wed Apr 30 01:41:20 PDT 2014
Does the corruption happen every time you save with a box open in edit?
If so could you give an example of a property box that causes it?
I've got users who are having this issue but I've been unable to
recreate it.
I've just tried having the identify box open and saving while in edit
mode and that worked fine, although it did also leave behind an
identical .qgs~ file.
If we can recreate it I can open a bug.
Cheers
Tom
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Joris HINTJENS
Sent: 30 April 2014 08:31
To: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Am I out of luck?
I have this problem often.
It is due to saving a file while a property box is open (in edit mode?)
It is a bug that causes the file saves only partially. You will see that
the saved file is smaller than the original
I solve it by restoring the previous version.
ALWAYS CLOSE ALL secondary windows before saving!
Joris  HINTJENS
Van: qgis-user-bounces at lists.osgeo.org
[mailto:qgis-user-bounces at lists.osgeo.org] Namens Ross Easterling
Verzonden: dinsdag 29 april 2014 20:14
Aan: qgis-user at lists.osgeo.org
Onderwerp: [Qgis-user] Am I out of luck?
I'm getting this error:
UNABLE TO OPEN PROJECT:
Project file read error: unexpected end of file at line 1 column 1 for
file C:/aross/OZ/GIS/state str.qgs
Am I just out of luck?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140430/c78d1312/attachment.html>
