[Qgis-user] QGIS from External drive ?
luca forestello fraelu at gmail.com
Mon Aug 11 02:24:58 PDT 2014
On Windows,
you can try this version of Qgis 2.4 that not requires installation and
does not require administrative privileges.
http://webgis.arpa.piemonte.it/pub/QGIS_portable_Chugiak_24_32bit.zip
You need to download the file "qgis_portable.zip", unzip the file (for
example, C:\Program Files\Qgis_portable, USB or external HD  should be the
same thing).
At the end of this operation, which can take several minutes, in the folder
"qgis_portable", you will find a new folder "QGIS" and a new file
"qgis.bat" (MS-DOS Batch File).
To start Qgis 2.4 simply double-click on the file "qgis.bat."
Kind regards
Luca Forestello
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140811/97bacf53/attachment.html>
