[Qgis-user] does someone know why I cannot export maps generated with openlayers plugin?
prossini prossini at csaricerche.com
Fri Aug 22 01:17:24 PDT 2014
Thank you Damien,
this are more details:
Project EPSG:3857
reprojection on-the-fly enabled
base openlayer: Google Hybrid or Bing Aerial (same problem...)
point shape EPSG:3004 (xMin, yMin 2309955.00,4898382.00 : xMax,yMax
2310320.01,4898709.28)
I've also tried to use a raster with EPSG:3857 as basemap and in this
case the map can be exported in pdf without problems,
thus I suppose that exportation/printing problems are linked with the
openlayer plugin...
thank you very much for your help,
Paolo
Damien Stephens wrote On 22/08/2014 02:28:
> Hi I have the same setup and am printing without issue.
> Can you give a bit more detail?
> Which open layers are you using, do you have anything else overlaying it, what grid system are you using.
> Will see if I can replicate.
> Thanks
> Damien
> -----Original Message-----
> From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of prossini
> Sent: Thursday, 21 August 2014 6:04 PM
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] does someone know why I cannot export maps generated with openlayers plugin?
> Hello to everybody,
> I'm trying to export maps generated with the openlayers plugin as pdf files (I tried also in svg or png...), but something doesn't work and the composer freezes until I don't restart QGis...
> Can someone kindly explain me how can I overcome the problem?
> Windows 7 Professional SP1
> QGIS 2.4.0-Chugiak
> OpenLayers Plugin 1.3.3
> many thanks,
> Paolo
> Dr. Paolo Rossini
> Istituto di Ricerca Gruppo CSA
> phone +39 0541 791050 fax +39 0541 791045 via Al Torrente 22, 47923 Rimini, Italy www.csaricerche.com
> THINK GLOBAL - ACT LOCAL
> Qgis-user mailing list
Dr. Paolo Rossini
www.csaricerche.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140822/81d3beda/attachment.html>
