[Qgis-user] Which Projection to use?
Joris Hintjens jorishin at gmail.com
Tue Dec 9 13:18:13 PST 2014
Thanks Joost and Nicolas
I did not find the richt EPSG Code because I was looking the code for zone U,V,W etc. I learned now that one for North and One for south hemisphere per zone does the trick
> Op 9-dec.-2014, om 17:12 heeft Andre Joost <andre+joost at nurfuerspam.de> het volgende geschreven:
> Am 09.12.2014 um 13:14 schrieb Joris Hintjens:
>> thanks Kristin and Nicolas,
>> Now I get which UTM zone I’ min, and I’ve been spending the last
>> hours in trying to find the corresponding EPSG code and/or the proj4
>> code to enter in QGIS. they are not listed in the default list in
>> Qgis Any suggestions welcome
> To get the UTM zone, simply add 3 to your local easting, divide by 6, round to integer and add 30. The UTM North zone EPSG code is 32600 + UTM zone, UTM South is 32700 + UTM zone
> HTH,
> André Joost
> Qgis-user mailing list
