[Qgis-user] Spatialite queries return text instead of numeric values
Alexandre Neto senhor.neto at gmail.com
Tue Dec 9 16:50:56 PST 2014
Hello,
When querying a spatialite database in the database manager, if you create
some calculations (say add two columns values) the resulting column returns
as TEXT instead of the expected numeric field.
Is this intended or a bug?
Trying to cast it as real, double or float did not work either.
Thanks,
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141210/7a3dab8c/attachment.html>
