[Qgis-user] py2exe for windows, import qgis.core anf qgis.gui
Nathan Woodrow
madmanwoo at gmail.com
Wed Dec 10 15:45:05 PST 2014
Hey Robert,
It can be done. I have done it with my Roam project, you can find the
setup.py logic here https://github.com/DMS-Aus/Roam/blob/master/setup.py
The three main things are:
1) Make sure you have a batch file that does path setup and call it
before running: python setup.py py2exe. You can see an example at
https://github.com/DMS-Aus/Roam/blob/master/scripts/setenv.bat I run this
is all my sub scripts when building, etc. Basically call setenv.bat call
2) You need to copy things like qgis provider plugins and resources into
the package, you can see that being done here:
https://github.com/DMS-Aus/Roam/blob/master/setup.py#L82 (ignore the mess
there)
3) You will need to do some path setup before you call QgsApplication or
else things will not load correctly:
https://github.com/DMS-Aus/Roam/blob/master/src/roam/environ.py#L107
The Roam code might not be a good example as there is a lot of other things
in there but you should be able to make your way though it to work it out.
- Nathan
On Thu Dec 11 2014 at 12:34:47 AM kissa hiri <kissa.hiri at gmx.at> wrote:
> dear community!
> I'm a newbie in mailinglists and qgis. I have progammed a standalone
> application in python and it works so far. Now I'm trying to make from that
> an executable file (*.exe) with py2exe (for windows) but I'm not able to
> include die qgis.core and agis.gui libraries. In the qgis directory I only
> found the qgis_core.dll and the qgis_gui.dll. Is qgis_core and qgis_gui the
> same like qgis.core and qgis.gui?
> please, help me.
> thanks in advance
> robert
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141210/c3a6432d/attachment.html>
