[Qgis-user] Export SHP2GPX Massively
Bernd Vogelgesang bernd.vogelgesang at gmx.de
Thu Dec 11 02:20:00 PST 2014
Sorry, can't figure out what is meant by "I need to move the axes of a SHP
track individual GPX each route..", but I assume that you have a shape
file with lines and you would like to store parts of that as tracks (or
better routes, cause you will not have a time component I think) in
separate gpx files?
I can think of solution by first splitting your shapefile by your line ID
with Vector -> Data Management Tools -> Split vector layer.
This will produce lots of shp files named with a schema like
layername_fieldname_ID.shp
Before that, adjust your original files column names to GPX conventions to
avoid trouble (Have a look at you already produced gpx files)
Then you could try to run a loop in a batch file with sth like this in it:
ogr2ogr -f GPX -dsco GPX_USE_EXTENSIONS=YES FORCE_GPX_ROUTE=YES
destination.gpx source.shp
See here examples
http://gis.stackexchange.com/questions/25366/ogr2ogr-convert-all-shapefiles-in-a-directory
how to build such a loop
or even without loop:
http://gis.stackexchange.com/questions/22349/converting-tab-to-mif-mif-to-tab/22352#22352
(all not tested by me, all just wild guessing)
Hope I got the topic right and that this will help you to find the right
way
Cheers
Bernd
Am 11.12.2014, 10:16 Uhr, schrieb Corredera_Estudio de Ingeniería GEOCOBET
CARTOGRAFÍA Y SIG <corredera at geocobet.com>:
> I need to move the axes of a SHP track individual GPX each route but
> massively, automatic, and not one by one, as the number of >tracks
> contained in SHP starting is very high and save them one by one to GPX
> from QGIS consume much time.
> Does anyone know of a way to make that transformation massively?
> Thanks and regards
>> Francisco Corredera Quesada
> GEOCOBET CARTOGRAFIA Y SIG
> www.geocobet.com    corredera at geocobet.com   (+34) 928 80 87 42
> Este correo electrónico y la información contenida en el mismo es de
> carácter confidencial. Se dirige  exclusivamente al destinatario
> mencionado en el encabezamiento. Si  el receptor de la comunicación no
> fuera el destinatario, le rogamos nos lo comunique de inmediato y proceda
> a destruir el mensaje recibido. Cualquier divulgación, copia,
> distribución o utilización no autorizada de la información contenida en
> la
> mismo está prohibida por la legislación vigente.
Bernd Vogelgesang
Siedlerstraße 2
91083 Baiersdorf/Igelsdorf
Tel: 09133-825374
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141211/172e774f/attachment.html>
