[Qgis-user] Export categorized layers
Joris Hintjens
jorishin at gmail.com
Thu Dec 11 12:33:51 PST 2014
The plugin GEarthView will do it nicely for you
The properties of the active layer will reexported to a kml.
greetings
Joris
> Op 11-dec.-2014, om 21:24 heeft sudeten <curt at slavniklabs.com> het volgende geschreven:
> What I did was to join the csv to a shapefile, then colorize the polygons
> within the shapefile by a value in the csv, and then export it to a KML to
> be displayed via google maps. However, the export did not have the color
> values for each of the polygons. Below is an image of the colorized map
> within qgis. The white lines are roads. I can not seem to save to a KML
> file that would display the exact thing (with transparent shading) in google
> maps.
> <http://osgeo-org.1560.x6.nabble.com/file/n5177523/ALBaldwin-1416.png>
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-Export-categorized-layers-tp5174610p5177523.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
