[Qgis-user] LizMap projects not loading
Víctor Manuel Herreros Villanueva
vherreros at ucm.es
Tue Dec 16 01:35:25 PST 2014
Hello,
I'm trying to set up QGIS server + LizMap under Ubuntu 14.04 x64bits
without success.
I'm using the nightly QGIS release 2.7.0 and the stable LizMap 2.9.1
release. Though I've tried other combinations (including QGIS server stable
2.6.0 and LizMap 2.10.0), the result is the same:
Every time I try to load a simple map through LizMap web client, my screen
hangs with the 'Loading map data' pop-up and, in the background, you can
see the message 'SERVICE NON DISPONIBLE'.
Even the sample projects from LizMap (e.g. Montpellier transports) don't
display.
I guess the error is due to some kind of QGIS mapserver missconfiguration,
but the 'REQUEST=GetCapabilities' tests through web browser give possitive
results.
This is the error I get from Apache2 log:
[Mon Dec 15 18:12:19.296986 2014] [:error] [pid 6498] [client
127.0.0.1:56213] 2014-12-15 18:12:19\t127.0.0.1\twarning\t2014-12-15
18:12:19\t[2]\tSQLite3::loadExtension(): SQLite Extension are
disabled\t/var/www/lizmap-web-client-2.9.1/lizmap/modules/lizmap/classes/lizmapProject.class.php\t326\n,
referer:
http://localhost:8080/lizmap/lizmap/www/index.php/view/map/?repository=montpellier&project=montpellier
[Mon Dec 15 18:12:19.313205 2014] [:error] [pid 6498] [client
18:12:19\t[2]\tfile_get_contents(
http://127.0.0.1/cgi-bin/qgis_mapserv.fcgi?map=%2Fvar%2Fwww%2Flizmap-web-client-2.9.1%2Flizmap%2Fvar%2F..%2Finstall%2Fqgis%2Fmontpellier.qgs&request=GetCapabilities&service=WMS&version=1.3.0):
failed to open stream: Connection
refused\t/var/www/lizmap-web-client-2.9.1/lizmap/modules/lizmap/classes/lizmapCache.class.php\t85\n,
referer:
[Mon Dec 15 18:12:19.313302 2014] [:error] [pid 6498] [client
127.0.0.1:56213] 2014-12-15 18:12:19\t127.0.0.1\tnotice\t2014-12-15
18:12:19\t[8]\tUndefined variable:
http_response_header\t/var/www/lizmap-web-client-2.9.1/lizmap/modules/lizmap/classes/lizmapCache.class.php\t89\n,
referer:
[Mon Dec 15 18:12:19.313378 2014] [:error] [pid 6498] [client
18:12:19\t[2]\tInvalid argument supplied for
foreach()\t/var/www/lizmap-web-client-2.9.1/lizmap/modules/lizmap/classes/lizmapCache.class.php\t89\n,
referer:
The first error states 'SQLite Extension are disabled', but SQLite
extensions are enabled, according to phpinfo():
Additional .ini files parsed: ... /etc/php5/apache2/conf.d/20-sqlite3.ini
sqlite3
SQLite3 support enabled
SQLite3 module version 0.7-dev
SQLite Library 3.8.2
Directive Local Value Master Value
sqlite3.extension_dir no value no value
Any idea for solving the problem?
TIA...
<http://www.ucm.es/> *Universidad Complutense de Madrid*
<http://www.ucm.es/> Dr. *Víctor Manuel Herreros Villanueva*
Jefe de Proyecto
*Gestión de EspaciosData Warehouse*
Jardín Botánico
Av. Complutense s/n
28040 Madrid
*Tfn. (+34) 91 394 7275 Fax. (+34) 91 394 4773* vherreros at ucm.es
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141216/34a4a707/attachment.html>
