[Qgis-user] Editing shapefile attributes in QGIS
Paulo van Breugel p.vanbreugel at gmail.com
Thu Dec 18 12:08:46 PST 2014
You can do a lot with the Table manager (you can find and install this
plugin via the plugin manager: menu --> plugins --> manage and install
plugins).
If that is not enough, you can of course always open the dbf file. I would
recommend using LibreOffice/OpenOffice instead of excel as in my experience
at least Excel can sometimes mess up the dbf file.
Paulo
On 18 December 2014 20:39:33 CET, David Bradley <dododave at gmail.com> wrote:
> Can someone point me in the direction of a better way to edit the data in a shapefile?
> Basically I want to export what is already in there to Excel, edit it, and then re-import it. The editing I need to do is to move a few cells into another column, add several columns, and remove many other seemingly superfluous columns.
> Thanks for any suggestions!
> David
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141218/32b81557/attachment.html>
