[Qgis-user] use autogenerated form in Qgis for same table in different postgres databases
Janneke van Dijk
janneke.qgis at gmail.com
Mon Dec 22 00:09:28 PST 2014
Hello Bernhard,
Thanks for the suggestion. I just installed the plugin. When selecting a
table and trying to initialise the layer I get a Database Error: syntax
error at or near "("
LINE1: EXECUTE ('public'.'T_network_geometry') (followed by more, I can
send the screenshot).
When I click OK the python error window shows:
File
"C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\datadriveninputmask.py",
line 188, in initializeLayer
inputUi = None, searchUi = None, helpText = "") # set the
defaults here because somehow some of the values persist
File
"C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\ddmanager.py",
line 176, in initLayer
readConfigTables = readConfigTables)
File
"C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\ddui.py",
line 371, in createUi
showParents, showChildren, readConfigTables, createAction)
File
line 200, in __createForms
n2mAttributes = self.getN2mAttributes(db, thisTable, anAtt.name,
anAtt.num, labels, showChildren, skip)
File
line 635, in getN2mAttributes
configList = self.configureLayer(ddRelationTable, [], {}, [],
{}, {}, [], db, True, "")
File
line 184, in configureLayer
DbError(query)
File
"C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\dderror.py",
line 54, in __init__
raise FatalError("DBError exiting")
FatalError: 'DBError exiting'
Python version:
2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
QGIS version:
2.6.1-Brighton Brighton, e2a51df
Should I do something else before initialising the layer?
thanks,
Janneke
On 22/12/2014 10:14, Bernhard Ströbl wrote:
> Hi Janneke,
> this is not answering your question... but, have you tried the
> DataDrivenInputMask plugin [1]. It auto-generates input masks for
> PostgreSQL layers. Only prerequisite is a properly designed database
> in respect to constraints, default values, data types.
> regards
> Bernhard
> [1] http://plugins.qgis.org/plugins/DataDrivenInputMask/
> Am 21.12.2014 15:44, schrieb Janneke van Dijk:
>> Dear all,
>> I have set up a form in QGIS 2.6 using the attribute editor layout
>> 'autogenerate', to edit an editable view in a postgres database. This
>> works nicely. I would like to use this form to edit data in other
>> databases that have an identical structure. Ideally, I would set up a
>> project file with all properties set where I could choose to load layers
>> either from one or another database (with identical structures), and
>> when I edit a layer the correct form opens.
>> If I save it as a .qml file (from project1 connected to database1), then
>> load it in project2 (connected to database2 with identical tables
>> loaded) through properties>fields>load style it appears to load it (the
>> edit widgets get changed to the same as in project1), but when I click a
>> value relation widget the layer, key column and value column fields are
>> empty. When I open the attribute table all fields that have a value
>> relation that refers to a lookup table that contains different values
>> than the original lookup table will show their values between brackets
>> (at least, those values that do not appear in the original table).
>> It looks as if the .qml retains a link to the original database and
>> lookup tables (and not just to layer names as they are loaded in the
>> project). Is there a way to configure a form based on a table structure
>> that can be re-used for other tables with the same structure?
>> Thanks,
>> Janneke
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> __________ Information from ESET Mail Security, version of virus
>> signature database 10911 (20141221) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
> signature database 10912 (20141221) __________
> http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141222/5b291721/attachment.html>
