[Qgis-user] use autogenerated form in Qgis for same table in different postgres databases
Bernhard Ströbl
bernhard.stroebl at jena.de
Mon Dec 22 01:12:27 PST 2014
Hi Janneke,
I published a new version of the plugin which includes the fix I
mentionend. Please check it out and call back if the problem is still
arising.
Bernhard
Am 22.12.2014 09:09, schrieb Janneke van Dijk:
> Hello Bernhard,
> Thanks for the suggestion. I just installed the plugin. When selecting a
> table and trying to initialise the layer I get a Database Error: syntax
> error at or near "("
> LINE1: EXECUTE ('public'.'T_network_geometry') (followed by more, I can
> send the screenshot).
> When I click OK the python error window shows:
> Traceback (most recent call last):
> File
> "C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\datadriveninputmask.py",
> line 188, in initializeLayer
> inputUi = None, searchUi = None, helpText = "") # set the
> defaults here because somehow some of the values persist
> File
> "C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\ddmanager.py",
> line 176, in initLayer
> readConfigTables = readConfigTables)
> File
> "C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\ddui.py",
> line 371, in createUi
> showParents, showChildren, readConfigTables, createAction)
> File
> line 200, in __createForms
> n2mAttributes = self.getN2mAttributes(db, thisTable, anAtt.name,
> anAtt.num, labels, showChildren, skip)
> File
> line 635, in getN2mAttributes
> configList = self.configureLayer(ddRelationTable, [], {}, [],
> {}, {}, [], db, True, "")
> File
> line 184, in configureLayer
> DbError(query)
> File
> "C:/Users/Janneke/.qgis2/python/plugins\DataDrivenInputMask\dderror.py",
> line 54, in __init__
> raise FatalError("DBError exiting")
> FatalError: 'DBError exiting'
> Python version:
> 2.7.4 (default, Apr 6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
> QGIS version:
> 2.6.1-Brighton Brighton, e2a51df
> Should I do something else before initialising the layer?
> thanks,
> Janneke
> On 22/12/2014 10:14, Bernhard Ströbl wrote:
>> Hi Janneke,
>> this is not answering your question... but, have you tried the
>> DataDrivenInputMask plugin [1]. It auto-generates input masks for
>> PostgreSQL layers. Only prerequisite is a properly designed database
>> in respect to constraints, default values, data types.
>> regards
>> Bernhard
>> [1] http://plugins.qgis.org/plugins/DataDrivenInputMask/
>> Am 21.12.2014 15:44, schrieb Janneke van Dijk:
>>> Dear all,
>>> I have set up a form in QGIS 2.6 using the attribute editor layout
>>> 'autogenerate', to edit an editable view in a postgres database. This
>>> works nicely. I would like to use this form to edit data in other
>>> databases that have an identical structure. Ideally, I would set up a
>>> project file with all properties set where I could choose to load layers
>>> either from one or another database (with identical structures), and
>>> when I edit a layer the correct form opens.
>>> If I save it as a .qml file (from project1 connected to database1), then
>>> load it in project2 (connected to database2 with identical tables
>>> loaded) through properties>fields>load style it appears to load it (the
>>> edit widgets get changed to the same as in project1), but when I click a
>>> value relation widget the layer, key column and value column fields are
>>> empty. When I open the attribute table all fields that have a value
>>> relation that refers to a lookup table that contains different values
>>> than the original lookup table will show their values between brackets
>>> (at least, those values that do not appear in the original table).
>>> It looks as if the .qml retains a link to the original database and
>>> lookup tables (and not just to layer names as they are loaded in the
>>> project). Is there a way to configure a form based on a table structure
>>> that can be re-used for other tables with the same structure?
>>> Thanks,
>>> Janneke
__________ Information from ESET Mail Security, version of virus signature database 10912 (20141221) __________
The message was checked by ESET Mail Security.
http://www.eset.com
