[Qgis-user] Version 2.2 Valmiera with SQL Server
Bernard BISconsult
emile.bernard at bisconsult.ch
Sun Dec 28 03:35:57 PST 2014
Hello friends
I'm using QGIS 2.2 Valmiera on a Windows 7 environment with SQL Server 2012
holding the data and I'm quite happy about how QGIS displays the data. The
connection to SQL Servre goes via ODBC. As in my project QGIS is used to
present data than to create or modify them, I use SQL-Server views as the
underlying data reference which works fine and fast. However I've got one
serious problem that is when I use the "Open Attribute Table" on a layer it
will show the exact number of records, but the record content is always the
same, probably repeating the content of the first record found instead of
showing the individual contents (see ccreenshot attached).
I thought this might be a 2.2 problem meanwhile fixed and installed QGIS 2.6
by using the existing .qgs file from 2.2. But after that many layers (not
all) lost there connection to the SQL Server database and I'm unable to
connect them. Furthermore using "Open Attribute Table" crashes on layers
from SQL Server.
By this mail I hope to get answers on:
1. How can I fix the 2.2 problem which displays repeatedly the same
record when using Open Attribute Table on a layer from SQL Server
2. How can I migrate a .qgs mapping from 2.2 to 2.6 which is mainly
filled with layers on SQL Server data.
Regards Emile
Diese E-Mail wurde von Avast Antivirus-Software auf Viren geprüft.
http://www.avast.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141228/c1dc4782/attachment.html>
Name: Screenshot - 28_12.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20141228/c1dc4782/attachment.jpg>
