[Qgis-user] Street Map
    Gabriele Baccini
    gbaccini at yahoo.it
    Sat Feb  1 06:15:15 PST 2014
thanks a lot guys
I'm trying to use mapnik and quantumnik to do it and I have found many styles for the shp (I have tuned it)
However, the problem arises for me to create a list of street names.
I need to create a grid with letters and numbers on this and identify ways as the example attached.
Do you konw how to do this?
when ... if I'll can finish successfully, I'll post a user guide of everything.
bye
Gabry
Il Venerdì 31 Gennaio 2014 22:47, kimaidou <kimaidou at gmail.com> ha scritto:
Hi
You could also download OSM data in Shapfile format, e.g. from Geofabrik website :
http://www.geofabrik.de/data/shapefiles.html
Load the layers in QGIS, then style them, or get some available in some shared repositories, e.g.
https://github.com/3liz/osm-in-qgis
You can then tune the styles (and contribute back if you want)
Cheers
Michael
2014-01-31 Gabriele Baccini <gbaccini at yahoo.it>:
Thanks for your answer.
>Have you try this progr?
>i see
>Gabry
>Il Giovedì 30 Gennaio 2014 17:42, Etienne Tourigny <etourigny.dev at gmail.com> ha scritto:
>It might be easier to install the software on your computer/server and required databases, modified to your needs?
>http://maposmatic.org/about/
>On Thu, Jan 30, 2014 at 1:23 PM, Gabriele Baccini <gbaccini at yahoo.it> wrote:
>I need to create a Street Map like the jpg attached
>>I don't know how to create a list of the roads.
>>there is a website (http://maposmatic.org/) using openstreetmap and makes these maps, but I have to use Qgis because I have to edit root maps.
>>Have yuo got any idea?
>>Is there a plugin that does it?
>>thanks
>>Gabry
>>_______________________________________________
>>Qgis-user mailing list
>>Qgis-user at lists.osgeo.org
>>http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140201/ca5c279e/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140201/ca5c279e/attachment.jpg>
