[Qgis-user] DB Manager
Alexandre Neto senhor.neto at gmail.com
Sun Feb 2 14:28:16 PST 2014
André,
I believe that DB manager (or actually the Postgis provider to QGIS) does
not like some expressions, maybe the CASE WHEN is the problem... I remember
having problems with the expression WITH foo as (...).
The good news are: You alredy found the workaround.
Alexandre Neto
On Sun, Feb 2, 2014 at 10:16 PM, Giuseppe Sucameli <brush.tyler at gmail.com>wrote:
> Hi André,
> what QGIS and PostGIS versions are you running?
> Regards.
> On Sun, Feb 2, 2014 at 3:59 PM, ALT SHN <i.geografica at alt-shn.org> wrote:
>> Hi list,
>> I've been struggling with DB Manager, and I hope someone can explain me
>> what the problem is.
>> I am querying a PostGIS table but when I try to load the SELECT results
>> to map canvas nothing happens! A simple example:
>> SELECT * FROM FREGUESIAS_2013 where freguesia ILIKE 'a%'
>> returns thos message in log winfow:
>> *Erroneous query: SELECT DISTINCT CASE WHEN
>> upper(geometrytype("area_ea_ha")) IN
>> ('POINT','MULTIPOINT','POINTM','MULTIPOINTM') THEN 'POINT' WHEN
>> ('LINESTRING','MULTILINESTRING','LINESTRINGM','MULTILINESTRINGM') THEN
>> 'LINESTRING' WHEN upper(geometrytype("area_ea_ha")) IN
>> ('POLYGON','MULTIPOLYGON','POLYGONM','MULTIPOLYGONM') THEN 'POLYGON' END,
>> st_srid("area_ea_ha") FROM (SELECT *, geom::geometry FROM FREGUESIAS_2013
>> where freguesia ILIKE 'a%'*
>> *) AS "subQuery_0" returned 7 [ERROR:  function geometrytype(double
>> precision) does not exist*
>> *LINE 1: SELECT DISTINCT CASE WHEN upper(geometrytype("area_ea_ha")) ...*
>> *HINT:  No function matches the given name and argument types. You might
>> need to add explicit type casts.*
>> Now the strange think is that if use this query as a CREATE VIEW, the
>> view can be added to map canvas! Any hints?
>> Thanks in advance,
>> André
>> *Sociedade de História Natural*
>> Departamento de Informação Geográfica
>> Polígono Industrial do Alto do Amial
>> Pav.H02 e H06
>> i.geografica at alt-shn.org <laboratorio at alt-shn.org>
>> www.shn.pt
>> www.alt-shn.blogspot.com
>> Facebook <https://www.facebook.com/SociedadeDeHistoriaNatural?ref=hl>
>> TLM: 964138188
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giuseppe Sucameli
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140202/c68996af/attachment.html>
