[Qgis-user] Metadata fields in QGIS
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Tue Feb 4 08:11:11 PST 2014
Hi List,
I'm wondering if anyone uses the "metadata" fields for data in QGIS
(Layer Properties -> Metadata)? I've been told that this is supposed to be
filled in manually.
I ask because I originally thought it was supposed to be filled in
automatically - http://hub.qgis.org/issues/8870 - And for OGC services
(WMS, WFS etc) this seems logical as all of the data is in the
GetCapabilities.
Does anyone have a view on this? Should the metadata be filled in
automatically or should the user enter it manually? My issue with the later
is that I guess the metadata is only saved in a .qgs file, and not the
source itself, so no-one else is going to be able to see manually entered
data.
Thoughts? Comments?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140204/52f2f480/attachment.html>
