[Qgis-user] QGIS shutdown python script
Larry Shaffer
larrys at dakotacarto.com
Tue Feb 4 10:36:26 PST 2014
Hi Ross,
On Tue, Feb 4, 2014 at 9:32 AM, Etienne Tourigny <etourigny.dev at gmail.com>wrote:
> You could place your code in your plugin's unload() method. But I'm not
> sure this would work, because some things might not be available at that
> time (e.g. layers, etc.).
> See this page for a simple example
> http://www.qgis.org/en/docs/pyqgis_developer_cookbook/plugins.html
> On Tue, Feb 4, 2014 at 7:41 AM, McDonaldR <McDonaldR at angus.gov.uk> wrote:
>> Hi List
>> Is it possible for QGIS to run a (python) script on shutdown? There is a
>> feature on the QGIS issues list about startup scripts (
>> http://hub.qgis.org/issues/6297) - can shutdown scripts be used in the
>> same way?
Have your tried putting that Python code in the closeProject() Python
Project Macro (in Project Properties dialog in QGIS 2.0+)? Not global to
the app, but it is already implemented, just at the per-project level.
Regards,
Larry
Say, for example, I have a project in which I am editing a dataset in a
>> spatialite database. At the end of the edit session I save my work and
>> shutdown QGIS. Before shutdown actually happens a python script/batch file
>> runs which zips the spatialite database and copies it to a remote server
>> location ready for processing by some other software.
>> Thanks
>> Ross
>> *Ross McDonald *| GIS Data Coordinator | Resources Department, IT
>> Division | Angus Council, Angus House, Orchardbank Business Park, Forfar,
>> DD8 1AT
>> T: *01307 476419* | F: 01307 476401 | E: mcdonaldr at angus.gov.uk | W: *Angus
>> Maps <http://www.angus.gov.uk/maps/map_home.cfm>*
>> This message is strictly confidential. If you have received this in
>> error, please inform the sender and remove it from your system. If received
>> in error you may not copy, print, forward or use it or any attachment in
>> any way. This message is not capable of creating a legal contract or a
>> binding representation and does not represent the views of Angus Council.
>> Emails may be monitored for security and network management reasons. Messages
>> containing inappropriate content may be intercepted. Angus Council does not
>> accept any liability for any harm that may be caused to the recipient
>> system or data on it by this message or any attachment.
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140204/77db85a1/attachment.html>
