[Qgis-user] Saving GPX as SHP looses the time part of the (date)time field
Alexandre Neto senhor.neto at gmail.com
Wed Feb 5 03:42:26 PST 2014
Hello Jukka,
On Wed, Feb 5, 2014 at 9:16 AM, Jukka Rahkonen <jukka.rahkonen at mmmtike.fi>wrote:
> I believe that this is not an accurate description: "only the date is saved
> as a string" but it is rather "only the date is saved as 'date'"
You are right the field with the name "time" (of type QDateTime) when
converted into shapefile is saved as a QDate field.
> I am not sure how much it is a bug because the dbf format that shapefile is
> using for storing the attributes simply does not support DateTime but only
> Date.
Ah ok, instead of a bug this is more a Shapefile limitation. And in this
case I agree that using Qdate instead of a string, might very well be the
best approach.
> But if you do not necessarily need just shapefiles a
> better alternative would be to convert data into Spatialite.
I did solve my problem, passing the data directly to Postgis using the
DBManager.
Thank you for your reply.
Alexandre Neto
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140205/c4525a7f/attachment.html>
