[Qgis-user] import osm-file to qgis
Larissa Hauser
larissa.hauser at bluewin.ch
Wed Feb 5 08:23:07 PST 2014
Hi there
as I have no experience in programming I am really struggling at the moment...
would anyone help me to get the attributes user id or/and user name of an .osm-file with it into qgis?
unfortunately, I do not manage to install and run the GDAL OSM driver http://gdal.org/ogr/drv_osm.html which might be of big value for my problem's solution...
thank you very much!
larissa
Am 05.02.2014 um 16:41 schrieb Andre Joost:
> Am 05.02.2014 15:26, schrieb Jukka Rahkonen:
>> QGIS, GDAL and OSM users should also remember that there is an excellent
>> GDAL OSM driver http://gdal.org/ogr/drv_osm.html.
> You can use it by simply dragging the .osm file into the table of content.
> Another chance is to use the spatialite_osm_map tool.
> Unfortuantely, all these (and the standard osm2pgsl importer to Postgis) strip of the osm user information during import by default.
> For the direct import with Add vector layer, you can edit the file ../QGIS Dufour\share\gdal\osmconf.ini by editing
>> # common attributes
>> osm_id=yes
>> osm_version=yes
>> osm_timestamp=yes
>> osm_uid=yes
>> osm_user=yes
>> osm_changeset=yes
> for point, lines, multipolygons, multilinestrings and other_relations.
> For osm2pgsql, it is possible to add those columns by uncommenting the last lines of the default style:
>> #node,way osm_user text
>> #node,way osm_uid text
>> #node,way osm_version text
>> #node,way osm_timestamp text
> HTH,
> André Joost
> Qgis-user mailing list
