[Qgis-user] item ID/UUID feature in print composer
Olivier Dalang olivier.dalang at gmail.com
Wed Feb 5 16:40:34 PST 2014
Yes the UUID is used internally. Actually, it's not even used by QGIS
itself, but by plugins.
And idea would be to remove this from the user interface, since it's
read-only and useless for the user...
I'll file a ticket for that !
2014-01-29 Andreas Neumann <a.neumann at carto.net>:
> Hi Otto,
> The ItemID is used for QGIS Server and any potential web client. You can
> set an ID on an item (e.g. a map and a label) and then the web client
> can send properties to set a property (e.g. label text) for that
> specific item.
> The GetProjectSettings command lists what items which IDs are available
> in a layout.
> The UUID I think is use internally by QGIS - but I am not sure about
> that and who introduced it.
> Andreas
> Am 29.01.2014 13:21, schrieb Otto Dassau:
> > Hi,
> > I would like to describe the item ID feature in the print composer a
> little
> > better in the manual. All we have is "With the Item ID you can create a
> > relationship to the other print composer items." and I don't really know
> > what this feature can be used for.
> > Can someone explain and maybe give an example, where the item ID and
> > UUID can be used and are usually for?
> > Thanks a lot
> > Otto
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20140206/0b6810f6/attachment.html>
