[Qgis-user] Postgis connection QGIS 2.0.1
    Bernhard Ströbl
    bernhard.stroebl at jena.de
    Fri Feb  7 01:01:58 PST 2014
Hi Sylvia,
I think people do not answer because your question is not very specific
and lacks details, let me explain:
Am 05.02.2014 12:02, schrieb Sylvia Preuß:
> Hello everybody,
> I have recently installed QGIS 2.0.1.
> Now I’d like to add a new PostGIS layer in a new project and filled out
> all connection parameters. But it takes hours to open all schemas and
> finally it’s not working at all.
I doubt it takes hours (but may feel like a long time for you)
Lacking information:
1) I _guess_ you can connect but you do not explain what is not working
2) any specs about your postreSql server or configuration
3) number of schemas on the databse and number of relations in the
schema (e.g. average) to give a feeling if it is a large or small database
some hints:
- if connecting takes long, simply click "stop" and see which
schemas/relations have been read and which have not
- tick "Don't resolve type of unrestricted columns (GEOMETRY)" and see
if that helps
> If I open an existing project from QGIS 1.7.4 it shows all of the
> earlier added postgis layers. I can create a new object and save it into
> the database. But after that, it’s impossible to update or delete it.
> It’s a postgis – view with functions and rules and is working fine with
> QGIS 1.7.4.
probably the functions or rules are not working as you expect them to,
nobody can tell if you do not show them
did you register this view in geometry_columns? if not and you have a
lot of them this could explain the long loading times escpecially if you
did not tick "Don't resolve type of unrestricted columns (GEOMETRY)"
because AFAIK QGIS reads _all_ records in these views and tries to
determine the geometry type (POINT, LINESTRING, POLYGON...)
> QGIS displays a short message like „couldn’t change object“ only. Where
> is a logfile or textfile for QGIS with all warnings and errors appearing
> during a session? In which path is such a file saved and what’s the name
> of it?
first check the log messages ("Protokoll" in German version) within QGIS
second check the PostgreSQL server's log
Bernhard
> Thanks for your help!
> Sylvia
> Der E-Mail-Dienst des Oberbergischen Kreises dient ausschließlich der
> dienstlichen Kommunikation.
> Senden Sie deshalb keine E-Mails privaten Inhalts an E-Mail-Adressen des
> Oberbergischen Kreises.*
> Es wird darauf hingewiesen, dass neben der Person, an die Ihre E-Mail
> gerichtet ist, auch deren Vertretung im Amt einen unmittelbaren Zugriff
> auf Ihre Nachricht hat. Für Berufsgeheimnisträger und besondere
> Funktionsträger gelten abweichende Regelungen.
> Es wird außerdem darauf hingewiesen, dass die Kommunikation per E-Mail o
> hne Authentifizierung und Verschlüsselung unsicher ist, da für
> unberechtigte Dritte grundsätzlich die Möglichkeit der Kenntnisnahme und
> Manipulation besteht.
> Es wird deshalb keine Verantwortung für den Inhalt dieser Nachricht
> übernommen, da eine Manipulation nicht ausgeschlossen werden kann.
> Obwohl alle angemessenen Vorkehrungen getroffen wurden, um
> sicherzustellen, dass Anlagen dieser E-Mail virusgeprüft sind, wird
> empfohlen, anhängende Dateien vor dem Öffnen durch Ihr eigenes
> Virus-Programm zu prüfen, da keinerlei Haftung für Schäden übernommen
> wird, die infolge etwaiger Software-Viren entstehen könnten.
> Der Inhalt dieser E-Mail ist ausschließlich für die bezeichnete Person
> bestimmt. Wenn Sie nicht der vorgesehene Adressat dieser E-Mail oder
> dessen Vertretung sein sollten, beachten Sie bitte, dass jede Form der
> Kenntnisnahme, Veröffentlichung, Vervielfältigung oder Weitergabe des
> Inhalts dieser E-Mail unzulässig ist. In diesem Fall wird darum gebeten,
> sich mit der absendenden Person der E-Mail in Verbindung zu setzen.
> __________ Information from ESET Mail Security, version of virus
> signature database 9383 (20140205) __________
> The message was checked by ESET Mail Security.
> http://www.eset.com
> Qgis-user mailing list
> __________ Information from ESET Mail Security, version of virus signature database 9383 (20140205) __________
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 9392 (20140206) __________
http://www.eset.com
