[Qgis-user] How to use Orfeo Toolbox tools in QGIS?
RNanclares raulnanclares at gmail.com
Fri Feb 7 07:33:02 PST 2014
Hi there,
first, you need to use the Osgeo4W 32 bit installer because OTB is not
included in the 64 bit installer, OR you can use the 64 bit OsGeo4w and then
install OTB from the 32 bit OsGeo4w (i don't really recommend it, IMO better
stick to the 32 bit OsGeo4w). After the installation you'll have to
configure the OTB folders, in my case:
C:\OSGeo4W\apps\orfeotoolbox (this is the folder in which i have installed
OsGeo4w 32 bit)
C:\OSGeo4W\bin
To install OTB run the OsGeo4W installer, then Advanced Install > Install
from teh Internet then in the Select Packages window click on the Libs
section (or type OTB in the Search Box) and install
Cheers,
R. Nanclares
View this message in context: http://osgeo-org.1560.x6.nabble.com/How-to-use-Orfeo-Toolbox-tools-in-QGIS-tp5102387p5102546.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
