[Qgis-user] Error in simple calculation in Field Calculator
Ramon AndiƱach custard at westnet.com.au
Fri Feb 7 14:24:25 PST 2014
On 07/02/2014, at 22:34 , magerlin wrote:
> Checking the Fields display in Layer properties displays:
> double, Real, Length 20, Precision 0
> Strange thing is you can't even type in a 10 digit number directly in the
> attribute table (well I can type in 1111111111 but not 2222222222)....
A large negative is definitely wrong.
It's also giving different results depending on how many fields are integers.
So, I'd go with bug. Are you able to add it as an issue?
(If not, let me know and I'll add it).
-ramon.
