[Qgis-user] Web-Client Pink screen and "FastCGI server closed connection" + "Premature end of script headers: qgis_mapserv.fcgi"
Gunnar Oehmichen oehm8895 at uni-landau.de
Mon Feb 10 07:45:31 PST 2014
Hello there,
i have hosted two projects on one virtual-host. One is looking fine:
http://biomass.uni-landau.de/qgiswebclient.html?map=../projects/f-w-vr2.qgs
while the second one is only loading a pink screen:
biomass.uni-landau.de/qgiswebclient.html?map=../projects/Solarpot_suew2014_3857.qgs
I have no idea what could be the problem. While accessing the second
map, apache error log:
[Mon Feb 10 16:38:04 2014] [warn] [client 139.14.20.144] mod_fcgid:
error reading data, FastCGI server closed connection, referer:
http://biomass.uni-landau.de/qgiswebclient.html?map=../projects/Solarpot_suew2014_3857.qgs
[Mon Feb 10 16:38:04 2014] [error] [client 139.14.20.144] Premature end
of script headers: qgis_mapserv.fcgi, referer:
[Mon Feb 10 16:41:09 2014] [warn] [client 139.14.20.144] mod_fcgid:
[Mon Feb 10 16:41:09 2014] [error] [client 139.14.20.144] Premature end
[Mon Feb 10 16:41:12 2014] [warn] [client 139.14.20.144] mod_fcgid:
[Mon Feb 10 16:41:12 2014] [error] [client 139.14.20.144] Premature end
were using QGIS, QGIS-Mapserver (Version: 2.0.1-2+precise1), Apache2 and
the qgis-web-client (checked out 28.01.2014).
Web-Client seems to be up to date:
$ sudo git fetch origin
$ sudo git mergetool origin/master
No files need merging
(allthough I have not found a way to merge with the origin and for
example keep my changes to GlobalOptions.js, had to reset the
GlobalOptions.js after merging completely replaced my GlobalOptions the
last time to account for my projects).
Thank you very much for your help,
Gunnar Oehmichen
Quantitative Landscape Ecology
Institute for Environmental Sciences
University Koblenz-Landau
Fortstrasse 7
76829 Landau
Germany
http://www.uni-koblenz-landau.de/landau/fb7/umweltwissenschaften/landscape-ecology/Staff/gunnaroehmichen
