[Qgis-user] oil gas symbols
Brent Fraser bfraser at geoanalytic.com
Thu Feb 13 05:18:40 PST 2014
 From http://blackbearddata.com/symbols download the zip file indicated
on their web page, then unpack into C:\Program Files\QGIS
Dufour\apps\qgis\svg
The in QGIS, Options -> System (scroll down to bottom)
At SVG Paths select Add, and navigate to the folder you just moved:
QGIS_Petro_SVG_Symbols
Add a point layer, open its Properties dialog, select Style, select
Single Symbol
In the "Symbol layers" panel, click on the "Simple marker" item (that's
the tricky part), then for "Symbol layer type" select "SVG marker"
Now to figure out how to assign the symbol by attribute...
Best Regards,
Brent Fraser
On 2/10/2014 1:51 PM, boxfour at earthlink.net wrote:
> I need to display unique well status symbols (oil gas). I saw the reference to Blackbeard that
> provides a symbol set, but the menus look different and when I try to load their svg file it doesn't
> see it when I go to select symbols for that layer.  It is a point layer. I have the latest version,
> version 2.  Am I doing something wrong, or does it not work in version 2?
> My shapefile does have a column for unique values for the symbol. ie 2 for permitted loc,
> 3 dry hole symbol, 4 for oil symbol 5 for gas symbol. Any suggestions?
> Qgis-user mailing list
